ManicMan
Probably not the best of stuff for the job but since I have plenty, I'm doing some building-like Sculpting with Polystyrene.. I think it's what is sometimes referred to as 'White Bead' polystyrene as it's the kinda standard old packing material which is like a bunch of white beads sandwiched together. Bit messy sculpting but for buildings and stuff, it's fine. Anyway.. Problem I have now is kinda the surface texturing. Using a heat gun to slightly melt the edges makes it a bit smoother and nicer for the job (yes, well ventilated).
Problem is still surface texturing.. in the past I've used a filler plaster and milliput but neither have fantastic griping properties. Wondering if anyone has any advise? Not the best stuff but cheap, easy to use stuff for light weight more bulky stuff ^_^
