Ordo Malleus Inquisitor Sylo, Bounty Hunter and Astartes
Frank FJA
Inquisitor Xuren Sylo
Inquisitor Xuren Sylo is a Psyker. He is armed with a Nemesis Demon Fist , Bolt Pistol and Artificer Armor. Sylo has many bionic enhancements such as his bionic respiratory system, built in detox purgation membrane to survive all but the most virulent of atmospheric conditions and poisons. Sylo is also augmented with a powerful Bionic Psyber-Eye that is capable of firing potent laser blasts. Belonging to the Ordo Malleus, Inquisitor Sylo is adept in all things esoteric and immaterial. His extensive knowledge of the Warp and its anomalies have helped him learn to control his innate psychic abilities better than most human psychics. This has caused many other Inquisitors to believe Sylo is a dangerous Radical and has even had to fight shadow wars against some of his peers that think him too far down a dark path of witchcraft. Regardless, Inquisitor Xuren Sylo cares little for what means and methods must be used in order to save the imperium. Sylo also has an intricate web of spy networks, mind controlled sleeper agents, hosts of imperial cells under his wing and various loyalties and pacts forged through the years.
Rakkir, Imperial Bounty Hunter.
Little is known about Rakkir other than he was once involved with the Savlar Chem Dogs regiment and it’s mining worlds. To what capacity is not known. Whether he was a criminal soldier or convicted offender sent to die in the laborious moons of Savlar doesn’t matter much anymore. Rakkir is a loyal Acolyte under the command of Inquisitor Sylo. He has aided in countless operations alongside the Inquisitor and his coterie of mysterious Astartes for many years.
Rakkir wears a fitted suit of custom Light-Power Armor crafted somewhere in the Savlar system. Typically Rakkir is armed with a variety of weapons ranging from power-blades of various shape and size, to digital weapons, combi-flame throwers, braces of pistols and a belt of esoteric tech including Hallucinogen, Psyk-out and tanglefoot grenades. When an operation calls upon for he and the Inquisitor to be in a dangerous full blown war zone, Rakkir instead sticks with more conventional Boltguns, Lasguns or sniper weaponry.
Inquisitor Sylo and Rakkir with their Retinue of Astartes from the Void Spiders Chapter...
To lean more about the Void Spiders Chapter you can check out my older post about them here: viewtopic.php?f=8&t=17263
Thank you for checking them out!
