Suber
Let's build some scenery today. I have to admit I didn't have any deodorant bottle at hand (the only proper way to build anything worth of Rogue Trader), but I substituted it by an empty hairstyling foam can. Closest I could get.
OK, so what am I trying here? In my mind I had the image of some Tatooinesque moisture farm, something of the like. So all I had to do was glue any rubbish I had in my bits box
The cologne tap will serve as the control console:
So once I had it all, I primed it white...
And then thought it would look better in desert-like colours. Well, I was wrong:
It definitely has to look white. Sooo, white primer again and then weathering/detailing:
Here you have it finished:
You can find all my mumblings on this on the blog. Now I wonder if I should build the whole moisture farm...
