Skarsnik
Prompted by another thread, I have a Warhammer Quest set to sell. It isn't complete, but it has all the important stuff, and the bits that are missing are easy/cheap to replace.
First of all it has no box, but other than that the contents areas follows (Bold is what was included in the original box, after is what I have):
4 Warrior models: Barbarian, Dwarf, Elf and Wizard - 3 present, missing elf, barbarian has a weapon swap, dwarf part painted, wzard unpainted.
6 Orc Warrior models: 2 present, no shields
6 Orc Archer models: 0 present
6 Goblin Spearmen models: 6 present, no shields
6 Night Goblin Archer models: 6 present
12 Skaven models: 12 present, no shields
3 Minotaur models:0 present
12 Giant Spider models: 8 present, 1 slightly damaged, 1 part painted
12 Giant Bat models: 4 present, all part painted
12 Giant Rat models: 12 present
12 Snotling models: 12 present, 5 part painted
10 Dungeon Doorways: 10 present
32 Page Rule Book: present, resonable condition, a bit of spine wear
16 Page Adventure Book: present, resonable condition, a bit of spine wear
192 Page Role-play Book: present, some wear to cover and damage to spine, a few of the back pages have started to come loose, but all are present.
1 How to Play sheet: Not present
50 Page Adventure Record Pad: Not present (can download these online)
19 Event Cards: 19 present
23 Dungeon Cards: 23present
30 Treasure Cards: 30present
17 Blank Event Cards: 0 present
15 Spell Cards: 15 present
4 Warrior Cards: 4 present, wizard card has a crease on it
4 Battle-level Cards: 4 present
4 Equipment Cards: 4 present
4 Warrior Counters: 4 present
6 Dungeon Rooms: 6 present, some slight wear to the edges from having the doorways attached
5 Objective Rooms: 5 present, some slight wear to the edges from having the doorways attached
7 Corridors: 7 present, some slight wear to the edges from having the doorways attached
1 Steps: present, some slight wear to the edges from having the doorways attached
3 T-junctions: 3 present, some slight wear to the edges from having the doorways attached
1 Corner: present, some slight wear to the edges from having the doorways attached
1 Portcullis Marker: present
1 Cave-in Marker: present
3 Pit of Despair Markers: 3 present
6 Webbed Counters: 6 present
15 Power Tokens: 15 present
10 Luck Counters: 10 present
18 Scenery Markers: 18 present
6 Large Dice & 12 Small Dice: 0 present (these are just standard d6)[/quote]
I'm looking for £55 plus postage for it.
