Suggestions for techno-penitent/flagellant/zealot model’s et
Wondering if anyone had suggestions for models that are suitable for techno penitents, or flagellants, zealots, or armed pilgrims?
Looking for something with a blend of low and high tech.
The necromunda redemptionists are an example of what I’m looking for generally (I like the arch zealot model very much, though I’m not blown away by the other sculpts in that range).
What else might I look to?
Ultimate goal is to use as frateris militia or cultists in games of 40k or RT.
Thanks for any suggestions.
Re: Suggestions for techno-penitent/flagellant/zealot model’
Are you looking for complete models or kit bash components? If it’s the latter, I’ve seen some interesting things done with WFB flagellants, Tabletop Art cultist heads and various 40K chain weapon bits.
I'm using the sisters of battle models with chainsaws- sisters repentia? penitentiary? something like that. They're great models but not easy to find cheap.
There's a ton of stuff like that out there...
Warfactory cultists, by our very own Scalene: http://lancerminiatures.com/index.php?m ... &cPath=123
Crooked Dice cultists: http://www.crooked-dice.co.uk/wp/product-tag/occult/
If can find them, theres the old Chainsaw Warrior Chaos Agent mini:
http://www.sodemons.com/rhrare/40kchaosagent/index.htm
Did TTG ever make 25mm Redeptionists for Laserburn?
These are some fantastic suggestions, thank you all for your input.
Loads of stuff that I had never seen before.
Stormbringer":19617o9x said:
These guys are distinctly WW2 era, but that might not be a problem, as all these weapons have Rogue Trader equivalents (autopistol, autogun, musket + combat accessory, flamer, heavy stub):
http://www.northstarfigures.com/prod.php?prod=7130
http://www.northstarfigures.com/prod.php?prod=7131
Agreed, they work for RT.
I’m very likely to take your suggestion of the frostgrave cultists and the sci fi sprue. And possibly a box of their gnolls because I’m planning on doing some sci fi beastmen. The North Star stuff looks very interchangeable.
Which is great for me, in that I prefer kitbashing to any serious conversions.
