Get to the otherside WFB
Having a hard time getting into narrative gameplay? Have a go at one of our scenarios!
Post Fri Oct 18, 2013 7:37 pm
If any bodies interested - these are the simply rules for the game I ran with the Oxfordshire Lads last week, using 500points each.
Get to the other side!
Movement
At each turn the player can make a single, double or triple move (their choice) to get from one f the table to the other. (March moves count as additional moves and thus roll again!)
Are they spotted?
If a players forces made a single move they will be spotted on a score of one on a D6; if the players forces made a double move they will be spotted on a score of 1 or 2 ion a D6 and if they made a triple move they will be spotted on a score of 1, 2 or 3 on a D6.
Modifiers: The players forces are cavalry +1, Forces are large creatures +1, forces cause fear/terror +1, Flyer GM’s choice.
What happens next - if, the player fails to score high enough.
Player rolls 3 D6 – one identifies how many come to investigate (wounds), Roll the number dices indicated to find out how many turn up 1 to 36!); the second indicates where (1 –rear, 2 right flank, 3 left flank and 4 to 6 front); the third tells you what has come to investigate! (1 - Giant, 2 – Chariots, 3 Orcs - H2H, 4 Orcs – Bows, 5 Goblins & 6 Night Goblins (Fanatics!; But basically- insert anything you what here to act as the marauders).
Example – first die score 3, then roll three dice – scores – 9, next die roll scores – 4 appear to units front, next die roll scores 2 – three chariots appear.
Example – first die scores 2, roll two dice scores 10, next dice scores 2 – appears to units right flank, next die roll scores 6 the enemy are 10 Night Goblins with one d3 of fanatics!
GM rolls a D6 to find out what they do – 1 Attack, 2 advance, 3 shoot, 4 Stand still, 5 stand for a turn then walk away and 6 they attack someone else (Nearest, if no one within reach revert to 1)!
Have fun
Paul / Golgfag1
How can I ever have enough stuff, I don't need.
https://golgfags.blogspot.co.uk/
In Dreamfish we trust
Post Fri Oct 18, 2013 9:06 pm
Re: Get to the otherside WFB
I have to say this was a lot more fun that it had any right to be with such simple rules.
As GM you do need to have a huge collection to cope with multiple roles ... (Chariots!)
Post Sun Oct 20, 2013 9:30 am
If you haven't got enough stuff - just roll again until you do have enough stuff of whatever is rolled up, as we did. (Currently, building more chariots!)
Paul / Golgfag1
Harry wrote:I have to say this was a lot more fun that it had any right to be with such simple rules.
Return to Missions & Scenarios
