Stripping Figures
Post Wed Nov 09, 2016 3:27 pm
Stripping Figures
For years I have always used paint stripper on metal figures and break fluid on plastics. Both are very messy, gloopy and a pain to clean up afterwards! Anyone got any other techniques they use and that go down the plug hole a little easier!!? I've heard some people mention they just use white spirit, anyone tried this with any success? I cant see it being that effective......
Look forward to any sugestions,
Tom
Post Wed Nov 09, 2016 6:19 pm
Re: Stripping Figures
I did a quick tutorial over on the Forum of Doom some years ago about using Dettol. It even has Oldhammer figures in it.
I'm sure the FoD could use the traffic should you want to check it out here
Post Thu Nov 10, 2016 12:18 am
Cheers matey that is a very good guide, I'll give it a try and let you know the results. From your photos you seem to have got the same finish I can achieve with paint stripper but with much less corrosive nastiness! Great stuff,
Tom
Post Fri Nov 11, 2016 1:14 am
I use Model Backup It is expensive but it is very quick and effective and can be reused many times.
Post Fri Nov 11, 2016 4:48 pm
Pure acetone for metals, works brilliantly, not messy but a bit smelly.I've got some cheapo paint stripper for plastics but it's messy as hell.
Post Mon Nov 14, 2016 5:34 pm
i use dettol for both. works a treat.
Post Mon Nov 14, 2016 6:41 pm
Another dettol user here. Sometimes grotty paints/ recessed detail can take a second/ third dunk to come up shiny.
Post Tue Nov 15, 2016 1:14 am
I use dettol but my usual opponent just can't get on with it. He always rinses with water before using fairy liquid and turns the half dissolved paint into a sticky mess. Always scrub with detergent before water gets anywhere near. I know some people use isopropyl alcohol for stripping but that stuff is not good for the lungs.
Post Thu Nov 17, 2016 6:13 pm
I*m a dettol user for bulk stuff but have had some success with ACETONE FREE nail polish remover for single figures. The ACETONE FREE stuff works very quickly 15 to 20 minutes and is very effective on metal and plastic BUT, note the emphasis, normal nail varnish remover with acetone will melt plastics almost instantly.
Post Fri Nov 18, 2016 7:59 pm
Thanks everybody! I can confirm my first success with Dettol and will continue to use it from now on. I got as clean a result as I would with paint stripper but without the third degree burns which suits me fine.....
Tom
