quidamcorvus
Tutorial: Teufelsberg, Shooting target.https://quidamcorvus.blogspot.com/2020/06/poradnik-teufelsberg-tarcze-strzeleckie.html
Construction of the village of Teufelsberg to Warheim FS is ongoing, and the next element that I decided to diversify the area are shooting targets.
Until now, in tutorials related to Teufelberg I showed you how I did:
- prussian wall
- tile
- thatched roof
- fruit trees
- cheese house
- wells
I invite you to read the above tutorials.
For the construction of shooting targets I used to skewer sticks, copper wire and plastic bits and a paper clip, and tools were among the cyanoacrylate glue and manual drill and knife.
Skewer sticks cut into 5 cm sections, three for each shooting target, from which I will build a tripod stand. Then I cut two of the legs of the rack at the joint and glued them in a V-shape.
I put the sticks to dry and in the meantime twisted braids of different thicknesses from copper wires, which I then rolled into a spiral.
In the next step, with a single wire, I twisted the arms of the twisted wire and made round handles - the latter finally turned out to be unnecessary and were cut off.
To strengthen the whole, you can soak with a few drops of cyanoacrylate glue.
After the glue drying the first two beams, I glued the third leg of the rack, and then wrapped selected elements with a rope made of tightly twisted two copper wires, which I also strengthened with a few drops of cyanoacrylate glue.
The time has come to mount the shooting targets, for this purpose I drilled holes in the rack, in which I placed hooks made of paperclip.
I decorated the tops of the stands with bits of banners.
And the last step, i.e. fixing the shooting targets on the stands and painting the whole with primer paint.
- prussian wall
- tile
- thatched roof
- fruit trees
- cheese house
- wells
