Vintage_Warhammer
Okay, so I've come from milliput (I use white exclusivly) - I love the way it dries hard and can be shaved using a very sharp scalpel blade for very crisp corners / sharp weapons edges. I love the way I can use a paintbrush and water to wet sculpt the milliput - gradual erosion of surface using a moist bruch allows for very delicate surface manipulation. I love the way I can hit it with 5mins of hairdryer heat and this speeds up cure to less than 1hr.
Why is is that everyone uses green stuff? and how do they achieve the above types of working processes? or is it impossible? I've been using green stuff and it stays very flexible meaning you naver acheive the same level of post cure grinding / shaving ability. I've found it's really ncie for making tubes and organic form, and things like chainmail but it's just irritating when you want to make a sharp edge.
Anyone able to point me to a good bit of information on how to work with green stuff after being so familiar with milliput and it's water reaction properties. I want to move to green stuff exclusively but can't seem to get the results I get with milliput
