Asslessman":1jkuxtv3 said:I usually start with a deneb stone base but I always lack the brightness I see in other people's whites. If I have lots of bright colours, I will strat with a grey prime (can't get myself to priming white...)
@Stonecoldlead : I'm intersted by what you say about matte mediums. I do use the PA one to either to prevent pigments to go straight in the recesses when I'm thinning paint or as is with just water, to kill the shineing effect of inks. What does the Tamiya X21 do? does it help with the consistensy of the mix or does it really kill the shiney effect?
Asslessman":2rwfodjl said:Sure, when masking is not a nightmare and that the shape is right, airbrushing can be a good solution too I guess.
ardyer":2cjoojt1 said:Asslessman":2cjoojt1 said:Sure, when masking is not a nightmare and that the shape is right, airbrushing can be a good solution too I guess.
If you're having to mask, your needle is too big or you're pulling to far back on the trigger
ardyer":7zcmd8ur said:...your needle is too big...
Asslessman":1lssludn said:@ Ardyer : I see that I have yet A LOT to learn with airbrushing
We use essential cookies to make this site work, and optional cookies to enhance your experience.
