Rescuing old Citadel Colour paints?
Post Tue Aug 13, 2019 2:47 pm
I've dug out a handful of vintage Citadel Colour paints from the bottom of an old art supplies box. One of them is a completely rock solid pot of Spearstaff Brown:
Spearstaff Brown
There's a solid lump of Worm Purple and Sunburst Yellow as well. Is there any way to rescue this paint or is it destined for the bin?
Keep Kalm and Pass Kool Tests.
Post Tue Aug 13, 2019 4:16 pm
Re: Rescuing old Citadel Colour paints?
Zhu Bajie wrote:I've dug out a handful of vintage Citadel Colour paints from the bottom of an old art supplies box. One of them is a completely rock solid pot of Spearstaff Brown:
A product was recommended recently on the Oldhammer Facebook group for this.
I seem to recall it being ‘acrylic paint reviver’ but after a quick google search with that term I didn’t see anything.
So this is not a very useful response, but yes there’s something out there that’s arguably useful.
Post Tue Aug 13, 2019 6:48 pm
I saved a lot of old paint pots with the newer Citadel Technical Lahmian Medium...
Although they were not rock solid, I was not getting any color from a direct contact.
After adding medium about 1/4 of the remaining dried out volume,
a couple of vigorous shaking and mixing with a small metal rod to break down the chunks of paint,
I was able save at least half of the dried out paint.
Good luck!
Et à ce j'ajouterai, santé!
http://plaiecivile.blogspot.ca
Post Tue Aug 13, 2019 8:05 pm
Thanks for the suggestions.
I've taken some advice and mashed up the solid lump walong with some Vallejo Airbrush Thinners using the handle of an ol brush, and while it's still very lumpy paintable liquids are starting to form - a step in the right direction!
I'm going to try using a metal bead as an agitator and the washing machine on spin-cycle as a vibration source to blend / liquify. Will try more manual mixing if that doesn't work.
Once the pigment particles have been separated by the thinners it will need a new medium to carry it, I don't have any acrylic medium at the moment so will have to pick some up.
Post Mon Sep 16, 2019 2:58 pm
Zhu Bajie wrote:I'm going to try using a metal bead as an agitator and the washing machine on spin-cycle as a vibration source to blend / liquify.
This was rather optimistic, and didn't work at all.
I did chop then grind in a mortar and pestle, adding small quantities of matte acrylic medium and acrylic airbrush thinners. This successfully made paint, but while some of it is smooth, it is quite bitty and not really fine enough for miniature painting. Perhaps with more grinding, or potentially putting it through something like a Nutribullet, or rigging up something with a dremel to smooth out the plastic at a subatomic level (lol), it would be useable. As it is, it's only good for basing.
Post Wed Sep 18, 2019 4:17 pm
at least you've increased the sum of knowledge on the subject!
Post Wed Sep 18, 2019 5:34 pm
daddyorchips wrote:at least you've increased the sum of knowledge on the subject!
The forum really needs a ‘like’ button ;)
