Willmark
To the best of my knowledge I haven't seen one on the web and as we all know, GW didn't create one back in the day... So...
Now I'm working on my Nippon Army over at Dogs of War Online and of course I'm looking through the Warhammer Armies book and Dark Elves are the only ones who can utilize Nippon. This of course leads me to digging out my entire Dark Elf army with its crappy circa 1991 paint job A few nights later I've stripped a ton of paint and am sorting and arranging models. So not only am I creating a Nippon army, but now I'm apparently working on a Dark Elf one (again) as well.
Then I get to the Witch Elves. I have 14 citadel ones & 8 Marauder ones. Now, normally I like/love Marauder minis, but not the Witch Elves, thus they get set aside. I'm not telling anyone here that the 3rd edition witch elves don't have a lot of dynamic poses and only one with her hands above shoulder level, making it tough to haul a war altar. This puts a crimp in my plans for a war altar now doesn't it? So what to do? Conversion time! As you see, not only did the witch elf model in particular that I used work for the altar but for a standard bearer too. I went with the same model because as you can see in the pics the left arm works perfectly to drill through and use a rod for the altar poles. The right arms I had to cut off and reposition and glue with some gray/green stuff coming later.
Some further thoughts: I debated going with a 40mm base in the vein of what I did with my chaos dwarf general over at CDO, but it didn't really work; too big and a tad too long. I even had another extra base for a dwarf Throne of Power, but that didn't work either. In the end I had to start creating it from scratch. Right now its pretty basic. Still not sure what I'm going to put on the top. I also remembered some old regimental bases for the bearers, but alas no round insert parts. While doing this I did noticed that three 20 mm bases in a line (20 mm by 60 mm) would work perfectly and allow it to fit into the regiment of Witch Elves.
Next up is a movement base for the unit and as you can also see I need two more Witch Elves with the human flesh from Mengil Manhide's regiment for the additional altar guard and two more 3rd edition Witch Elves and I'll have a regiment of 20.
Enough talk here are the photos:
Here is where I started at as the basis of the conversion.
Snap to ladies!
Lining up
Lift on three!
Front View
The regiment WIP (once again? 25+ years later???)
That's it for the moment.Thoughts welcome.
EDIT: Head to here for further updates, by Dark Elf Army Rebirth Project: viewtopic.php?f=6&t=7899
Snap to ladies!
Lining up
Lift on three!
Front View
