Dreamfish
Administrator
I'm not sure if the same applies to acrylic paint, but just like when painting windows frames, always remove the tape while the paint is still wet. Although, I don't think painting the shade/highlight with the tape still attached would be any easier. The thing is, paint still gets underneath the tape, especially when using a brush. You have to work quick, because the tape will lose its grip after a while. I used normal painters tape. I believe the results can be improved with better tape quality.
The best part with this method is the precision in determining the position of the lines. You can see that the lines on all fists are similiar in direction and position. This is much harder to achieve when painting freehand, I think.
