For those who are not too keen on following blogs, I thought I might share with you my plan to build a super demonic chaos engine of doom aka Chaos grav attack aka deostick tank.
Like the name of the sub-forum it's in, it is a WIP.
I started with this :
and drilled a 20mm hole on top of it with a power driller (first and maybe last time I ever do that ) and started adding some pieces I had lying around
to get something like this :
The result clearly not being RoC and RT to me, I decided to sculpt some demonic face on the front getting inspiration from Nico's shields for his marvellous chaos knights.
Still a lot to do but theottovonbismark's tips about sculpting in the Venator thread have proved very helpful and I'm learning a lot in the process, doing things one step after the other.
Next step is some facial surgery to fix the parts around the eye and giving a "Lana Del Rey" touch in the form of lips.
I've considered using thin metal sheets (the one from tomato tubes) but I think it will be far too thin. I want the lips to be the metallic sheets of the vehicle opend by th emutation so I'll give a go to making GS thin sheets and see...
