MadHatter's K'daai Fireborn (Rogue Trader raw material)
Once upon a time on Chaos Dwarfs Online before the End Times, MadHatter and I conducted a special miniature trade. I had bid for some Squat Exoarmour suits on Swedish Ebay, but that headgear fanatic bidded higher! When this was discovered, he offered me the uncorrupted Squat Exoarmours for my 40k army, if I converted the Chaos Squat Exoarmours into K'daai rocketjumpers for him. Said and done.
This might turn out to be both the first and last commission sculpt not intended for casting that I'll ever do outside my circle of close friends (except for some odd small quickjobs). As a principle, I don't accept unique commissions. If lots of work shall be poured into something, it should better get available for lots of collectors in the end by casting and selling. If I sculpt for only one customer, only that one benefits from all work. If I sculpt for casting, dozens or hundreds can benefit from the fruits of one's labour. Easy equation.
Ladies and gentlemen, let me reveal to you the exception that proves the above rule: The hot, the soaring, the crazy K'daai unit of Madhatter!
The explosive powder fuel of the Rocketrisen contain a critical ingredient, namely distilled souls of mortals. As the exhaust flames shoots out, anyone beholding the spectacle of the volatile Daemonjets may catch glimpses of faces shrieking in agony, quickly come, quickly gone in the impossible stream of powerful flames.
The leader of the nigh-on suicidal Rocketrisen is a living testament to the lethal dangers to both body and soul of these maniac warriors. Having lost both sanity and feet to baleful accidents, the Daemonsmiths have replaced his legs with large exhaust ports shaped like rune-carved cloven hooves. Thus the infamous, cackling madman continues to lead his handpicked brethren, seeming to live only for the pyromaniac slaughter of foes and innocents alike. Truly the terror of the battlefield.
Twin fuel hoses hang from the lips of the grisly metal mask which adorns the clumsy fullplate armour suit. When properly activated, the union of their flames may produce sorcerous bolts which the bearer, assisted by fell Daemonic runes in his arcane armour, may direct with some rudimentary grasp of magic. "Spitting firebulls" is starting to become a common proverb in some parts of the dark empire of the Dawi Zharr. Needless to say, the inherent risks to the bearer would make uncorrupted Dwarfs recoil in horror at the mere thought of the insane rashness.
Here we see a dreaded Rocketrisen during steeplechase exercise.
Obviously, the experimental rocketsuits are dangerous in the extreme to the user, and the slightest malfunction or mishandling can lead to severe injury, maiming, madness or death for the bearer. Here we see a Rocketrisen flailing and swearing as he spins skyhigh out of control, a common occurrence. Note the head spike, which transform Rocketrisen flight mishaps into armour-penetrating projectiles capable of felling huge monsters.
And together with the flayman Elfskin which MadHatter won at a random prize draw in a previous contest.
Curis
Nice work converting the guy of the right of the unit's feet, resculpting the armour plates into a more flighty pose.
