WL Moved forward 8" GF Suffers animosity @ RGH, moved forward 3.5" KYP Suffers animosity @ SBB, wheeled right 3.5"
Airbornegrove:
KBP2 Shot @ MB, killed 0 LTK Charged @ WoP I Moved forward 3" F Moved forward 3" S Moved forward 3" MF Moved forward 3" A2C Moved forward 1.5" on difficult ground MO Moved forward 3" on difficult ground TT Flyed @ +10 level, accl. 8", current speed 16"
Thantsants:
WoP Holds SOC Charged @ KBP2 MB Charged @ KBP2 RGH Charged @ WL W Moved forward 5" @ RGH right flank RLR Turned around K3C Moved forward 3.5" CGC Changed formation to 6 files, moved forward 0.5" SBB Turned left
KBP2 loses 1st round against MB, automatically routs and is annihilated
Rogaine captures the Percolator and brings the Chariot to a halt
LTK keeps the witch elves at bay
WL Skidded forward 3" @ rock WLH Moved 8" @ left bridge
Airbornegrove:
KBP1 Wheeled from the center 2" (complex manoeuvre) I Moved forward 3", changed formation to 5 files, failed 2nd manoeuvre F Moved forward 3" S Moved forward 3"
Thantsants:
F1 Moved forward 8" @ S, wounded 1 F2 Moved forward 9" @ S, wounded 1 W Moved forward 5" @ RGH K3C Moved forward 2.5", halted within 4" of enemy CGC Turned around
I've now worked out it takes about 3 days for me to write up a turn. I'm not sure if thats faster than before I had a child or not, but I suspect probably not. Anyway, I'm on day two, so hopefully I'll publish turn 2 tomorrow!
D - just want to check - I suspect that the wood elves fled because of the fear of the cold one - is that correct?
Right, aiming to finish tonight (latest tomorrow!) - but I have a question. I see that the boarboys (or Rogaine) took a wound (based on the red splat in the battle chronicler picture), but I can't see where this happened in the dicelog? Is this because Rogaine failed his cool check when reaching for Percolator in the 1st combat round?
